I'm a proponent of reclaiming pool cover surface water rather than simply pumping to drainage.
Also, I maintain a 3,000 square foot garden, located some 500 feet away from the pool.
With an artesian well and no city water, I've previously pumped water into 30-gallon drums, hauled them to the garden, then pumped out the barrels.
This takes much time and effort, and the water flow from barrels into the garden is expectedly weak.
So...
1 - Would incorporating a pressure washer at the end of the run significantly speed up the actual watering of the garden?
2 - Would a powerful enough pump omit the need for filling multiple drums and allow me to pump directly from the pool cover to the garden?
3 - Can you suggest a more efficient alternative method of getting water to my garden?
Thanks in advance!
-A
So...
Thanks in advance!
-A
