Hi All,
I wanted to see if I can get some feedback/advice on the best path for me to upgrade my pump. Currently we have a Hayward Max-Flo II XL 2HP pump that is very noisy and oversized for a 14k gallon pool. We have no features (no heater, water fountain etc) and the pump is on a 4hr per day cycle. Ideally I really want to avoid any re-plumbing if possible as I don't really know how I could without cutting into the concrete (pics attached). From looking around this sub I think I have 3 options and wondering which seems to be the best way forward. I'm looking to redo and automate in the next 3-5 years so that's the time horizon I'm looking at so really trying to do it as cheaply as possible. The pump is on a concrete pad, but is currently raised with a piece of plywood and slate around 0.75" - I'd plan on replacing this with some vibration damping matt of sufficent thickness to have everything line up.
Option 1:
Replace the pump with a Hayward Max-Flo XE VSP with 1.65 THP. This seems to be the lowest risk option, I think I can get this for about $899 and as best I can see has equivalent dimensions on the inlet/outlet.
Option 2:
Replace the motor of the pump with something like the Nidec NPTQ225 THP2.25 VSP, seems like I can get this for around $550 and then would also need a Go-Kit for $50 and I believe I can use the same impeller and diffuser. I'd then need to change the motor myself and hope I don't break anything along the way
Option 3:
Get the Calimar 1.65THP VSP like this one and replace the entire pump. From reading the specs, I'm looking at about a 2.5mm difference in distance from the inlet to center of the outlet from my current pump which I would assume is close enough (maybe not though). I think this would be about $400 before shipping.
Are there any other options I'm overlooking? My rough calculations says that I'd save around $700 a year with a VSP so even the most expensive, but safest, option 1 would pay for itself fairly easily.
Appreciate any feedback!
Option 1:
Option 2:
Option 3:
