- Jun 12, 2023
- 124
- Fiberglass
- Jandy Aquapure 1400
I'm not sure what the problem here is, but my main filter pump (Jandy 1.85 VS Pump) is unable to pull from my main drains. Theres a 3" line that runs from both main drains, and T's off into 2 pumps. 1 pump (a 2.7HP Waterways VS Pump) is ONLY fed by the main drain, and has zero issue (even at low RPMs) pulling from it.
On the filter pump, there is a 3 way valve that allows me to switch from skimmer, to main drain, or any combination of both. Anytime I introduce any amount of MD to the mix, it loses prime and is unable to pull water through the pipe. I've tried just about every combination of valving to get it to go, and nothing allows the pump to prime.
Anyone have any thoughts on what the issue may be?
Heres an older pic of the plumbing setup. The pump to the left is the waterfall pump, which is only plumbed to the 3" main drain line. The pump to the right, is the filter pump, which has a jandy 3 way valve split between main drain (left) and skimmer (right)
