- Mar 24, 2016
- 37
- Plaster
- Jandy Aquapure 1400
I have a Jandy Stealth 2 speed pump that is sucking air from the cap that covers the debris trap. Has anyone else experienced this issue with these pumps. I contacted Jandy and they recommended replacing the gasket which I already did and they said if that didn't work I would need to order a new lid. The pump isn't even 2 years old and to me the construction of these lids is set up to fail, the clear window isn't part of the lid its like a 2 part lid and the window spins around in there until the lid is locked in place. I have a picture pointing to the spot on the lid that is sucking air and from what I can tell there isn't a gasket or anything to make a seal where the clear plastic window meets up with the main part of the lid.
