Pump seems clogged
Aug 27, 2016
145
Duncanville, TX
I have noticed that the pump seems clogged lately. The pressure rises and the flow from the return line slows tremendously. Then the pump basket loses some water and isn't full like normal. I have been turning the pump off, emptying what little debris there is in the pump basket and starting it back up. But, the next day I experience the same thing. This morning I decided to backwash the filter. That seemed to help, but I noticed the green stuff coming out of the return line. I am in the SLAM process, so maybe that's why? I just read the thread info on Deep Cleaning a Sand Filter. I will try it this weekend, hopefully. If someone thinks something else could be wrong please let me know.
Starting with the sand is a good idea, work on the obvious problems before you start looking for gremlins. You could also double check the skimmer make sure the weir door is moving freely, if it get stuck it can cause the pump to starve for water and thus have more air in the basket.
Ok. Thanks. It looks like backwashing helped.
