Bought a house with an above ground pool in disrepair. Got liner installed, filled with water. Went to inspect pump this morning as it had filled overnight. Water leaking out of output of pump. Disconnected flange between pump and filter and tried to unscrew output line (pvc) , line broke off with threads in pump. Decided to try to turn pump on for a second to verify it even worked, faint hum, no water movement. Tried to turn valve on top of sand filter, wouldn't turn.
2 questions:
Old pump is 1.5 hp Hayward and sand filter and in line clorineator (puck holder) Hayward also, do I just need to replace whole kit and kaboodle, if so should I go with a 0.5 hp pump since pool school says it'll be fine (24' round 48" deep around 13.5k gal), should I go with another 1.5 hp,?
Should I replace whole sand filter or can I just get a new valve?
Thanks
2 questions:
Thanks
