I have a Hayward SP32950VSP that I purchased in 2000. I pressed quick clean and resume buttons a few times (too quickly) and the pool pump started quick clean then shut off in about 2 seconds. I pressed the menu button and the best I can recall display showed manufacturing code test mode. The pump ran for approximately 60 minutes and then ran at half rpm for 10 hrs. Now I get “keypad failed key error 66.” I turned the power off at the CB. I then I removed the display cover thinking water intruded onto the circuit board as I got the display wet. What is code 66?
Thx
Thx
