I have a VS pump and have programmed it as follows:
2 hours at 2800 (to drive the pool sweep)
8 hours at 1450 to filter and run the SWG.
When my timer came on yesterday to start the first 2 hour run the pump would not prime. It timed out after 10 minutes. It tried several more times but it still would not prime. For the third try I threw the valve that diverts water to either the pool returns or pool sweep return to the pool return setting (i guess I had lft it in the pool return line setting which results in a higher filter pressure) and the pump primed and then ran normal.
Not sure why this is happening. Does anyone have an idea of what might be causing this and what i should try to fix?
