Finally ready after 10 days of opening SLAM! Before starting SLAM I converted to a SWG using a vertical install kit. This morning when I kicked my pump over to run on the timer it shut off and I noticed that the water in the pump basket slowly went down. I turned the pump back on and it started up again, but it did take a couple minutes for it to prime and fill the pump basket again. I guess I don't remember in the past paying much attention to whether it did this same thing before I cut out the chlorinator and installed the SWG. My question is if it's normal for the pump basket water to empty when the timer kicks the pump off? If this is not normal, I am concerned with my pump burning up by having to prime for several minutes each time it's time for it to run again.
On another note...once my water gets above 70 degrees I plan to turn the SWG on. Do I need to wait until the FC levels come down to normal to test for salt or can that test be done anytime?
