Weather went from 50 F to 80 F in two days ... as usual
. Opened up the pool & went to turn on the Hayward pump ... the pump won't turn over. Had the same problem last spring but was able to turn the impeller by accessing through the back panel. This year it seems to be seized so tight that I can't budge it. I'm thinking I may need a new pump - disappointing as the pump was replaced only 5 years ago.
In the meantime, is there any benefit to starting to shock the pool without the water circulating?
Thanks!
Thanks!
