I was in the middle of backwashing and rinsing my filter tonight when I encountered a problem with my pump motor. I switched from BW to rinse and the motor didn't sound quite right (I do turn the pump off when switching my valve). I immediately hit the breaker but as I did, I heard a pop from the motor. I swapped back to BW and flipped the breaker back on. The pump started, but was slow. It came up and ran fine. I swapped back to rinse and got it came up and did fine again. I now have it on filter and the pump is doing fine with typical discharge pressure and the motor sounds fine. I have limited eletrical knowledge, but I believe I blew the start capacitor on the top of the motor. Does this sound right? Is it ok to let the motor/pump run? Everything seems ok. Will I be able to replace the start capacitor and could this have been caused by me stopping and starting too fast? Sorry for the many questions.
