Hey everyone, I opened my pool a little late this year, and for the first time in 5 years I had a green pool when opening it. There were a couple of rips in the cover, and I'm guessing a lot of Crud got into the pool over the winter.
Anyway, I cleared everything out, got the filter and pump running and the algea started clearing up. Green is gone, and trying to maintain a slam, while the cloudy water clears up, but some some reason the pump keeps loosing pressure. What I mean is the output pressure from the return jet keeps dropping.
After a couple of hours, last night, It did it. There wasn't enough in the skimmer basket to cause it, but I cleaned it out and restarted it. Turned it back on, it was okay. Checked it a little while later, same thing.
I back washed the filter this afternoon, got some dirt and gunk out, rinsed it, and tried again. After a little while, same thing. The water is cloudy, but it's not full of large debris, the filter can't be clogged again.
What's going on with the pump? The strainer basket in the pump doesn't have a lot of junk in it either.
Again, it runs for a while then looses pressure out of the return eyelet. What am I overlooking?
When the outlet jet loses pressure, if I turn the pump off, and then turn it right back on, it's back to normal pressure. For a short time.
