Pump leaking
ajyb6789
2
Hello, I have a bad leak coming from the bottom of my pump. The pump itself is a century ST1152 serial 13818CH. It’s attached to a Hayward sp2610x15 housing?(not sure what this part is called but where you can see the water)
I have ordered a gasket set for the haywardsp2610x15. I replaced the seal that goes around the housing where you can see the water from. The kit is from Amazon (image attached)
Will this work for my century pump? I tried searching online and can’t find much.
Thank you for your help
