Pump Installed, Freeze Warning Prep
KBoy420
50
Eastern PA
Hi all. Had to put the pump in early due to a leak. Anyway we have a freeze warning for tonight into tomorrow. I plan to just let the pump run all night. Anything else I should do to make it thru the next 24 hours without any broken equipment?
just let it run :)
If you want you could throw a blanket or tarp over the pump and filter area just to provide some heat retention..
Reactions: KBoy420
