Hi all,
I've been noticing my system seems to take longer to prime and push out bubbles on startup.
I have cleaned my filter, checked skimmer and pump baskets and all are clean.
The slow prime seems to be worse when it starts up with the solar heater...which makes sense because that's where all the air would be.
I know my motor is on the way out due to bearings being a little louder at times and having water ingress after a bad shaft seal. It’s on my list to replace I be next few months, but since this has been a known issue before the prime issue... don’t want to point a finger at it right away.
System has no leaks, water or air, and the SWG was cleaned recently too.
