I just opened my above ground pool this past Wednesday. I got out as much debris as I could with the next. The only stuff left now is so fine it goes straight through the net. I have fine particles on the bottom of the pool and floating on the water surface. Every time I try to vacuum I lose suction and have to turn my pump off and back on. Then after it runs for a while, I lose pressure. If I turn the pump off and then turn it back on, the pressure will return but only for a little while. I vacuumed 3 times yesterday because it kept losing suction. Finally, the water became so cloudy I couldn't see anymore and just stopped. The water looked worse than before but I figured it was because I had just stirred up everything. I'm in the middle of a SLAM and took a reading. My CYA is running around 40 so I've been trying to maintain a FC of 16. Well, my reading showed 0 so I adde 3 gallons per pool math. Later than evening, I ran the test again and I got a super high reading of like 31. I let it go and waited till this morning and ran another FC test and it's dropped to 21 and is still very cloudy. I had very little pressure coming through the return. I turned it off and backwashed it. The water wasn't really bad at all so that's not the reason for the loss of pressure. I don't understand why I'm losing so much pressure and why it's still so cloudy. I set up for my readings to be attached to my signature so I hope when I post this it will add it.
