- Sep 22, 2011
- 211
Is it normal for my pump basket to drain water when the pump is off? In other words, the pump runs fun and the basket fills up with water when it's running, but once it's off the water level inside the pump basket drops. So the next morning, the water in the pump basket is down a few inches and it has to re-prime when it starts running again.
I'm having an issue with high pressure in my DE filter. For some reason, my pressure goes up quickly. I was backwashing every few days and I thought maybe I was adding too much DE, so I started backwashing and not adding DE. Even doing that, the pressure would go back up again in a day or two. Even with no DE being added after several backwashes, the pressure still would go up after a few hours.
Last night I took apart the filter and I didn't see anything obviously wrong. The filter was about 95% free of DE, so my backwashing is working fine. I even took apart the manifold to make sure there were no clogs, etc. All of the piping and everything inside the filter looked good. The air hose on top of the filter was very clogged though with DE and some type of pool toy that apparently disintegrated and made its way into the filter. It looked like blue and orange foam type material. There wasn't a ton of it, but it was caked around the air hose inside the filter. I read that when that clogs, it can cause pressure issues so I'm going to see if that fixes the issue.
My research has suggested that an air leak on the pump side can cause pressure issues because the air builds up inside the filter and increases the pressure. After thinking about this morning, it occurred to me that the pump basket should probably remain full of water even when the pump is off and the fact that its not probably means I have pretty substantial air leak somewhere and that may be causing my pressure problems.
I did replace the gasket for the pump basket lid last year or the year before that and I applied magic lube to help seal it, but maybe the lid is bad? I need to take a closer look tonight.
