I've been keeping my neighbors pool chemistry in check until he finishes remodeling his new home and moves in. We just had a lot of rain dumped on us so I went over to check on the water level in his pool. As it was still raining heavily and the water had reached the top of the skimmer I set the filter to waste to dump some water out of the pool. I noticed after doing this that the pressure in his sand filter went down about 3 psi. My question is this. If the system is pulling air (which I suspect it is) is it possible for the waste setting to relieve the filter of this air pressure? Is there another potential cause of this psi drop? A bit of background on my neighbors pool. 20 x 40 IG vinyl pool with only one skimmer acting as a return source to the pump/filter. 2 returns which I often witness discharging air bubbles. Single speed pump that runs 24/7 and no relief valve on the sand filter. SWG, and an ionizing system (which I took the liberty to unplug).
