- Oct 9, 2021
- 28
- Fiberglass
- Pentair Intellichlor IC-20
With the WhisperFlo VST I programmed three speeds. One is for 3,000 RPM for when I run my vac.
I have an open button on the Panel in the No.6 position. From the Names List I chose to rename this to ""Bottom Cleaning".
From the speed setting I chose the Circuit "Bottom Cleaning"
So when I press this button No.6, the pump speeds up as it should.
Trouble is, sometimes the controller turns on No. 6 without me pressing the button No.6
I only want to be able to activate button No.6 manually, but it seems something else is activating it?
