IG vinyl 19797.23 fc 0.1! Ph 7.5 cya 72 alk 75 ch 380 no reading for total chlorine at the moment, no borate.
apologies of this is covered elsewhere, but I have looked and can’t find an answer.
I have just attempted to remove iron stains from my vinyl pool, using ascorbic acid in conjunction with sequesterone and some polyquat to keep the algae at bay during the process, as fc has to be reduced to zero and ph lowered. I am also having to use a Scuba II photometer kit as it is sadly impossible to get any of the better kits in Europe at the moment and I have run out of reagents for my dpd pro kit.
The results on the staining are good but I now seem to have a problem. The Scuba II read free chlorine as 0.1 the day after completing the process above, with all other readings, as above quite normal. This morning I tested again. fc is still reading 0.1, which having added the bleach yesterday morning would seem impossible, especially as it was not a sunny day. My feeling is that either the dpd1 tablets sent with the machine are old, the machine is faulty or there is a legacy from using polyquat, sequesterone and ascorbic acid. Does anyone know if completely depleted chlorine is a result of using any of the above? I have contacted the vendor of the kit and requested a new one/ fresh tablets. I have added more chlorine this morning but am nervous of allowing anyone to swim as I really have no idea of the chlorine level.
I am really desperate to manage the pool water and am now relying on a test strip system which is impossible to read accurately. HELP!
