I'm having a heck of a summer with this pool. After an Ascorbic run and adding the purple stuff, everything was great. Then I went out of town, and it rained like crazy. Came home to a hazy and green pool.
Got the FAS-DPD test and did a OCLT last evening/this morning.
Original readings:
Salt: 3000 PPM
FC: 8 PPM
PH: 7.4
ALK: 124
CYA: 20
OCLT
Last night:
FC: 3 PPM
CC: 4.5 PPM
This morning:
FC: 3 PPM
CC: 3 PPM
Based on the CC reading, I started a SLAM this morning. I'm hoping this is the right direction to go in. Every time I SLAM, the pool gets stained with Iron, so once my SLAM is complete, I plan on doing a run of Ascorbic acid again to get the stain off. The pool this summer has been a maintenance nightmare. Also learned yesterday that my return jets were set up wrong. They were pointed center straight up (both sides of the steps) and I adjusted them down and to the right. Now I have a good circular movement of the water and hopefully will help me keep the PH balanced better since there is less aeration with the new configuration. Thanks for this group for advising to get the additional testing gear I need. Hopefully we'll be able to enjoy this pool at some point this summer.
Original readings:
Salt: 3000 PPM
FC: 8 PPM
PH: 7.4
ALK: 124
CYA: 20
OCLT
Last night:
FC: 3 PPM
CC: 4.5 PPM
This morning:
FC: 3 PPM
CC: 3 PPM
