When we replaced our heater last spring we didn't get a wind stack which the old unit had as we don't live in an area that has high wind issues. It was fine until the other day. I turned it on and when I came back to check on it there was an IF code. After doing some research I figured out that it was the wind - it was unusually breezy. It was back to normal yesterday when conditions were calm. Since we've had no other instances of that code and we don't normally swim when very windy I don't want to rush out and get a stack installed.
So, my questions are a) how windy does it have to be for this code to happen? b) where on the unit is the air entering to cause this code? I am wondering if placing some sort of barrier near the unit would block the wind enough to prevent this code? The unit is located at the narrower side of the house so it's somewhat sheltered.
Also, I want to check the orifices just in case. I've read that this should be done at start of each season. Are they easily accessible when opening the panel and an easy diy or do i need a tech to do this? I haven't found any videos on how to do this.
