Prevent algae before pool opening?
Joshii
277
Every year, I open the pool in May. About a month before opening, the pool turns green and I have a 1-2 week fight getting it crystal clear after I open. Is there anything I can do to prevent this? A little chlorine or algaecide pre-opening?
The formula for opening is simple really - the sooner the better. While the water may still be chilly, the sooner you increase the FC level (and confirm other levels) to begin circulation/cleaning the better. Adding an algaecide after the water has begun to change color would be useless, and depending upon the algaecide used, could cause more problems later (copper). Open early, start water circulation, and adjust chemicals so the water can bounce-back is your best bet. :)
