Is there general guidance on when is the best time to do pressure testing? Our PB uses an air gauge not water gauge. What can you share on testing LED lights in the pool both when there is water in the pool and then AFTER the pool is drained of water.
Should lines be pressure tested before the pool is replastered? There will not be any further pool patio work deck work done - the concrete is in place. No further skimmer work. There is tile and stone work needed, pool shell preparation and I am concerned about a LED light leak that was quickly repair as water was coming though the pool wall behind the light just before the plaster was done. How does a pool light leak when there is no water in the pool at all? Trying to understand what we can do pressure test wise before the re-plaster work. Thank you for your input.
