- Jun 22, 2014
- 52,184
- Fiberglass
- CircuPool RJ-45 Plus
Jessica, they are correct. You have only one pipe coming up into the pump from the pool. Look in the bottom of your skimmer. Do you see a diverter disc at the bottom - looks like a UFO thingy?
At the filter, you have the plunger valve. The small pipe going straight down is waste from backwash. The other pipe goes to the 3-way valve to let water go back to the pool in two pipes - return jets and something else? You'll have to look around closely. Maybe a pressure cleaner option? Is there a small port (covered) around the side wall of the pool somewhere? Besides the return jets, anything else that may use water (bubbler, spillway, fountain, etc)?
