Hello all,
My wife and I are in the process of buying our first home. It has a pool that hasn't been open for at least 7mo or more. Thankfully it has a "cover" (big tarp with weights on the decking)...and the cover has fallen into the pool exposing about 3' across the width of the pool to the oak tree above.
In order to get the home inspector to inspect the pool, they need to be able to see the sides/bottom and main drains. This inspection is on Monday afternoon. I have the ability to access and clean the pool to prepare for inspection. I plan on scooping the bottom for debris, vacuuming, sweeping the pool, and cleaning the filter during the next few days, along with adding chemicals.
I've seen two schools of thought for clarifying the water 1) chlorine and muriatic acid or 2) Algicide and FLOC
What would y'all recommend for a quick fix to facilitate the inspection?
Thank you!
Poolnoob210
Thank you!
Poolnoob210
