My pool is 2.5 months old and have had no trouble with water balance or algae. For the most part the plaster looks good and uniform, but for some reason in the deep end there a few dark areas. The PB said that mottling is common, but the beach area and shallow end is near perfect and the deep end is less than stellar. There's light areas and then really dark areas. It looks worse from the surface than when I go down to the bottom and inspect. The dark areas are a condensed area for the micro pebbles and less plaster where as the lighter areas are more plaster and less micro pebble. Before start up the plaster was acid washed. This was supposed to help decrease the mottling. Am I being too meticulous or is this something the PB should fix?
pool by Beccah-shawn Alberti, on Flickr
_SKA4602 by Beccah-shawn Alberti, on Flickr
_SKA4603 by Beccah-shawn Alberti, on Flickr
_SKA4605 by Beccah-shawn Alberti, on Flickr
_SKA4606 by Beccah-shawn Alberti, on Flickr
