Hi All,
I have a couple of questions about combined chlorine and signs of mustard algae. I am currently only using liquid chlorine for my sanitizer, no pucks. I have been doing that all season because of high cyanuric acid levels, but those are now back to normal after draining and filling multiple times slowly the last few months. I adjust the chlorine every night to stay in the 2-3ppm range. I counter act that with muriatic acid to keep the pH in check. I also keep on eye on the alkalinity and adjust accordingly. I have managed to keep my combined chlorine at 0 all these months. Maybe once or twice it was at 0.2 or something after a heavy rain. That cleared itself up on it's own with a little extra chlorine.
Every week or so I see what looks like sand in two or three areas around the perimeter (not near the return jets really). I chocked it up to possible fine sediment from the new zeolite that was added to our sand filter when we changed the sand this season. I did come across this video, though, which made me think a bit more on it:
When I brush the small pile I see, it does plume up like in the video. It does not sweep into a pile or anything. It's usually in a seam in my vinyl liner.
So to my questions:
1. Do you think it could be mustard algae?
2. Would my combined chlorine be showing as 0 if I indeed have mustard algae?
3. Should I shock just in case even if my combined is at 0? I would bring my chlorine levels to about 12ppm with liquid chlorine. Would I be doing any damage to anything or am I wasting my time and chemicals?
Current Levels:
21,000 gallons, vinyl pool
Chlorine 2.6
pH 7.6
Alk 110
CYA 35
Calcium 200
Copper 0.43 (issue I was having all season, got it down finally from 3.2)
So to my questions:
Current Levels:
Chlorine 2.6
pH 7.6
Alk 110
CYA 35
Calcium 200
