Position of intake and return
Dcookster
0
89
Stafford Va
My manual only says “make sure the skimmer and water return holes are located where you need them to be. The skimmer and water return holes are positioned towards the end of the wall, (the section before where the wall started)” I’m installing an 15x30 oval pool, I’m thinking I should have the service panel land on one of the a curved ends or does it matter? Pool is located down at the bottom of a slope so I don’t think the wind travels much any direction. The wind pretty much gets block by house and privacy fence. What’s you opinion? Thanks for any replies.
Skimmer location is usually determined by the prevailing wind direction.
If the pool is shielded from the wind, mount it where it is most convenient to do so.
