So, the return fitting I have does not have an eyeball which means I haven't had the ability to change the direction of the water flow. I'm thinking that means the water has her flowing slightly to the right, but only on the surface. Maybe that's why everything settles to the bottom. Do you think I am right? If so, I just need to get the correct return fitting that has an eyeball. BTW- I inherited the pool from previous owner.
ETA: I was aerating here to raise PH, normally it's pointed down into the water
@canjones, can you post a picture?
We don't have a good directional eyeball either, so we used the vacuum adapter on our return =) It works great and also gave us a good current we can ride
I have no idea. The previous owners left a manual from Doughboy.Something like this "aftermarket" return might also work for you?
Infusion Threaded Inlet V-Fitting
You would need to match your inlet thread/pipe size
Is that a Pentaris brand return cover?
UPDATE: I decided to purchase the Infusion V Fitting. I wanted to give it a try before going with the circulator. So far, a little more than half the pool is clean (meaning nothing settled on the pool floor). The part farthest away from return line had some dirt settled on the floor yesterday. I am hoping to be able to go at least 2 or 3 days without brushing. I fear that my problem is I only have one return line and a large pool. Next step will be the circulator if I am not satisfied.
Yes. I put it at an angle. I moved the angle higher last night just to see what it would do. Because with the angle I had the leaves weren't moving towards the skimmer. Now, that I moved the angle higher I'm back to where I started with leaves and dirt in the deep end (which is closest to the return line). Only good thing is that the pool floor still isn't as dirty as before with the original return fitting I had.Do you have it pointed at a downward angle, not just straight down?
