PoolMath target level 2 pools
datadr93
201
Eastern Ohio
Fiberglass
Pentair iChlor 15
When I setup a 2nd pool (hot tub) I noticed when you set a target level it causes pool 1 to have the same target level.
I was baffled when I configured salt level for hot tub. When I was back to pool 1, it was suggesting I drain 50% of my pool to reach target. That's when noticed the target I set for hot tub was now target for pool.
Same issue occurred with all target values.
Is this a known bug?
Target levels can be set for Salt and Borates for each pool. I've confirmed that target levels for salt, when set for different pools, maintain that target based on pool selected, on my version and device.
All other target levels are based on pool type enumerated here:
email [email protected]. Include screenshots, device and version information (menu/about TFP will give you version).
There does appear to be some wonky actions with salt that I’m able to recreate that appears to maybe be related to cache. We’re fixing to shortly release an update that may address this issue, but I’m not 100% sure just yet. Can you drop me an email at [email protected] so I can bounce back and follow up on this with you?
Sending email now with some screenshots for reference.
