So my wife and I have been looking for our home for nearly 2 years, we've been through several offer situations on houses with and without pools knowing that a pool is a must have for us. We have finally found the house for us and had a well known and respected vinyl installer come out at our home inspection for his thoughts.
Those of you in Metrowest MA have heard of B&L I'm sure. Paul was super nice but unfortunately he felt he was not capable of putting a pool in our yard.
For setup the house has a steep grade in the back. When it was built a portion of the yard was built up to accommodate a level yard with a patio; however, this area is not large enough for a pool nor far enough for setbacks. The grade appears to be about 10 foot drop over 100 feet (researching on topo maps) but it's a bit more gradual in the area we are talking about.
It started with access, he was concerned about getting to the back yard and said it would need to be graded to ensure a truck wouldn't tip.
Next, we discussed the grade. He basically said if we built straight out from the land we were on, we'd need way too much fill to make it feasible. In my mind I was thinking we'd start at the low point and dig out the hill with retaining walls, but he said "That'd be a lot of work."
Lastly, he told us we were probably better off going gunite because at the end of the day we'd probably save money rather than if we did vinyl + all the retaining walls. The entire discussion was "that's going to be a lot of work." "That's expensive" "That's a budget buster" We left feeling like Paul was not interested in the job in anyway, basically excuse after excuse. Told us he basically assumed there was no way a pool was happening when he first walked the lot.
After some research, we found radiant pools may be an option with a nice block wall on the above ground portion; however, I found this lovely forum and a pool build in 2015 by B&L that seemingly had less access, a wooded lot, lots of rocks, and a steep grade. Paul made it work and apparently was the only one to save the day for those home owners. After finding that story, I'm concerned it is literally not possible.
I'm hoping some local pool owners can give us some confidence that a radiant dealer or concrete wall vinyl/gunite installer can turn this into reality. Anyone have build logs of similar grades?
