Since I moved in here ten years ago the pool umbrella has been a pain.
The main issue is the plastic insert embedded in the pool surface doesn't quite fit the poles on pool umbrellas, it's tight and can be hammered in with a rubber mallet and is secure but this has always puzzled the heck out of me. Furthermore the top part of the interior of the insert has a thread and I have no idea what that is for.
Here's a photo I just took of the insert:
You can barely see the thread but it is there. Below the thread the entrance narrows slightly (you can that shoulder part) and that's the part that the umbrella tube doesn't comfortably fit into, as I say it's tight as heck, one can push it in by hand up to a point but a few taps with a rubber mallet gets it in further and stable.
Of course its then extremely hard to remove and even when closed strong wind sometimes snaps that Dang thing and this is a yearly farce for me, sometimes if it snaps it's a huge effort with tools to get in the water and remove the broken remnant of aluminum tube.
The umbrella tubes are 1.5" outside diameter.
What am I doing wrong? is that hole even intended for an umbrella at all? why is it thread near the top?
