Re: Pool turned green and they got pool stored, time to help
This part sucks but you'll have to test again right before sunrise. If the FC is still a few shades darker you passed the overnight free chlorine loss test and you're done. If not, try to read the strip FC level the best you can. Since the water will now be exposed to sun all day, I would hit it a little harder to account for UV loss and aim for 16ppm. Input the strip reading into the FC Now and 16 into FC Target on the PoolCalculator to figure out how much bleach to add.
Can you check the ingredients so I'm not just assuming it's dichlor? How much did you put in so we can keep a running count of your CYA level? If you added 1.5lb your FC went up by 13 and CYA will go up by 11. CYA takes awhile to show up on the test that's why your latest tests didn't show an increase. If it has all been dichlor you should be around 30ppm CYA making your shock level now 12ppm FC instead of 10.DanielleW said:I already put the shock in before I read the post. LOL. Figures!
The basic 2/3-way test kit has OTO Chlorine/Bromine and Phenol Red pH drop tests. It can only measure total chlorine up to 5ppm which is too low to be of use to you. On the other hand the pH test in the basic kit is fine. The TF-100 includes a basic test kit mostly for the pH test. The strips can read up to 10ppm FC so they are really your only option until you can get a TF-100 or Taylor K-2006. Again, you just need to make sure the color on the FC test is a few shades darker than the 10ppm color to maintain your shock level. If you really want to, you can always dilute your pool water sample 50/50 with distilled water and multiply your test strip result by 2. In that case you'd want the strip to indicate 6 or above.I am also going to see if I can get a basic test kit until we can get the better one. I just worry about my test strips!!
As long as it takes to not drop more than 1ppm over night. Make sure you SWG is off and set to stay off. Add the bleach, wait 30 minutes with the filter running. Then test with the strips to make sure the indicator is darker than 10. If it's not dark enough, add more bleach. It's better to go over than under. Once you get there let the filter run all night.How long do I need to maintain the chlorine lvl above 10ppm? So if I do it tomorrow night after sundown, test it and then test it again early Wednesday morning and it's still above 10ppm, I'm ok, correct? If it drops, I need to repeat again on Wednesday night? I want to be sure I understand this correctly!
