I'm getting ready to install an liner in my pool (16x32 inground w/ plastic steps) and have a question about the gasket around the pool steps.
I bought a roll of neoprene gasket material and am not sure how to go about installing the gasket.
First, should I run the gasket in one continuous piece and bend it around the corners of the steps, or should I cut pieces for the 2 vertical and 1 horizontal surfaces and butt the ends together? And if so, what should I use to seal the corner joints?
And second, what should I use to hold the gasket onto the steps?
Thanks in advance for the help!
