Hello,
About 2 years after our pool was built we started having issues with the bubbles in our spa which then resulted in no bubbles at all. I'd call a pool company here and there to look at it and one replaced the blower (1/2 HP) and "blew out" the lines and the bubbles worked again. The next year it stopped working again and I couldn't get the same pool company out so a different one came out and said there wasn't anything they could do to solve the overall problem of the blower having to push so much water for so far. So he again "blew out" the lines and the bubbles worked again.
Unfortunately I wasn't able to be there for either service call so there was no witness to the "blow out". I have to assume a shop vac or air compressor was used but where? There's a (I think it's called) a check valve that seems operational - do I remove the cover and use that opening to "blow out" the lines? I have all the tools, I just don't know where to put the shop vac and/or air compressor. Any suggestions? I tried a male air compressor port above the check valve but that didn't work.
