- Mar 24, 2019
- 195
- Plaster
- Hayward Aqua Rite (T-15)
I asked about this a few weeks ago but I’m finally starting to track accurate test results a lot better so need some advice. I thought the pool size was originally 20k gallons, the pool builder couldn’t find the original build paper work but that’s what they estimated it at. With that beings said...
The CYA was 0 so I used pool math and for a 20k gal pool with a goal of 70 CYA it recommended 12 lbs of CYA. Just to be safe I subtracted a 1/3 off of that (to keep math simple since I was unsure of the actual pool size) and added 8lbs. Did the good ol pillow case hanging from the diving board for a day and then hung it from a pool chair while squeezing it infront of the return jet. Finally got it all to dissolve and checked the CYA today (2 days later) and it is 35.
My 2 questions are:
1. Do I need to wait a couple more days for a more accurate CYA reading (I’ve read it can take days for it to get in the system)?
2. Since 35 is half of my goal of 70, I did the math in pool math and that would actually mean to reach 35 CYA by adding 8 lbs of CYA the pool size would be 27k gallons. Is that correct and how it works? Sorry if this is confusing.
My 2 questions are:
