Question while slamming, l have read the SWG shouldn’t on during the slam procedure. When you setup the pool in the math app while slamming do you choose bleach or SWG?? Hope you understand the question? Thanks in advance for any replies.
Your SWG (any SWG) is unlikely to be able to maintain the FC at SLAM level when your chlorine has work to do. SWGs excel at maintains FC, but they are rather limited on how much chlorine it can quickly generated.
I don’t think PoolMath design accounted for that line of thinking.
Use the "Bleach" option for Liquid Chlorine used during a SLAM process. Turning your SWG off allows you to monitor chlorine loss (use) better and saves lifespan on the device.
Even if u choose swg in the settings when setting things up, when u get to the overview page & select the fc card you have the choice to select bleach to reach your goal. The same holds true with the effects of adding tool.
