I just pulled the trigger on an IG 18x36 rectangular pool. The pool will have double main drains and 2 skimmers (all independently plumbed 2"), and 3 returns (independently plumbed 1.5"), and another return w/ jets in the lounge area on the long end of the pool. Pump is an Intelliflow, with a 420 sq ft cartridge filter. The attached image shows the layout, with the prevailing wind direction coming from mostly southwest.
Where would you guys recommend placing the skimmers and returns? I was originally thinking of putting one return in the stairs, and 2 returns on the long end of the pool closest to the house, and the skimmers opposite the returns on the other long end.
However, the PB said this was NOT a good setup, as I would end up with 2 clear paths between return & skimmer, and in between would be dirty. He recommended putting a return to the right of the stairs, and a skimmer to the left of the stairs, and on the opposite short end, a skimmer on the right side, and a return on the left. He said this would provide a circular circulation w/in the pool. I have never seen a setup like this, and am hesitant this is the optimal setup.
I've also considered putting all returns on the short end with the stairs, and the 2 returns on the other short end of the pool, since this is the prevailing wind direction. I'm just not sure they will push through 36' of pool.
Any pointers, help, or guidance would be most appreciated.
Thank you!
- pc
Thank you!
- pc
