Pool return direction
Pool_Medic
In The Industry
Apr 1, 2018
1,450
Bangor Maine
All returns should be pointed in the same direction. How high on the skimmer mouth are you keeping your water level? Too high and they will not create much suction if any.
bmoreswim
Platinum Supporter
6,814
Central MD
Hayward Aqua Rite (T-15)
I'm not at all convinced that the aiming of your returns has anything to do with your water clarity. And I really believe it has zero to do with it. Sure, in an ideal world, the volume of pool water is nicely circulating about throughout the water column. But just by the pump running, the water in the pool gets circulated pretty well. Maybe not well enough to skim effectively, or to eliminate dust settling in one area versus another, but almost certainly well enough to distribute chemicals, which is the primary the reason for cloudy water. As stated earlier, the water is just as cloudy in the shallow end as the deep end, it is just more obvious when looking through more water depth.
My advice is, in order to obtain the best possible skimming, is to continue fine tuning your return directions. But to obtain clear water, test and treat your water properly, which if your water is cloud (i.e. not crystal clear) is to follow the SLAM Process.
I notice that you are not sharing your Pool Math logs. Can you share a complete set of test results, and what test kit you are using to get them? That will allow us to address chemical issues.
Reactions: Mdragger88
Bperry
242
Knoxville, TN
CircuPool RJ-60
I have a similar dead zone in my pool, curious to see if any improvements are found. I just have one of the kids go out with a net once and a while to skim the surface.
Pool_Medic
In The Industry
Apr 1, 2018
1,450
Bangor Maine
You can get different “eyeballs” for your returns that can assist with flow, remember water goes its easiest route, normally the first return has lots of flow where the others off that line won’t, that’s where I put a smaller eyeball to force the water to other returns.
Mdragger88
1,928
Hernando, Ms
Intex Krystal Clear
Still struggling a bit here. Good news is the deep end of my pool seems to be clearing up toward the bottom of the pool. Less hazy. Not crystal clear yet, but an improvement. I attribute this to adding DE more frequently to my and filter and the return jets pointing down vs up. I'm still very much struggling with the surface of the pool, however. Thoughts on pointing jets down and toward the skimmers vs left or right?
Edit : the leaves and other floating debris tend to move in circles in the shallow or deep end of the pool, several feet from the skimmers.
Are you backwashing when pressure rises 25% over clean pressure?
DerekBooth
87
Mooresville, NC
They are. I only adjust them to point up and out to push the floating scum toward the skimmers because that seems to be the only way to avoid using a net on half the surface of the pool daily. Water level is about halfway.
Clarity has improved a ton. I was slamming already when I posted this thread. I've also been adding DE fiber to my sand filter.
Here is my current log.
Build Type: Vinyl
Volume: 25000 gallons
Latest Test Result Summary:
FC: 6.0 (8 minutes ago)
CC: 0.0 (8 minutes ago)
pH: 7.6 (8 minutes ago)
TA: 60 (8 minutes ago)
CH: 10 (8 minutes ago)
CYA: 55 (8 minutes ago)
TEMPERATURE: 50° (one month ago)
Any suggested eyeballs? Mine are all the same size. 3/4" I'm guessing.
Yes, but that takes many days usually.
Pool_Medic
In The Industry
Apr 1, 2018
1,450
Bangor Maine
If you are getting any debris in your skimmers then they are working. If you have two skimmers and they are not both plumbed independently then the second one won’t have pull if any. Water level can affect skimming action as well, 1/3 up the mouth of the skimmer pulls more than 1/2 up the skimmer. Having the main drain open too much will reduce water being pulled by the skimmers. Placement in regard to prevailing winds can also affect their pull.
DerekBooth
87
Mooresville, NC
They're plumbed on the same line and both catching debris. Main drain is open maybe 5%.
I've played with water levels and watched the sucking action of each skimmer and I believe they're optimal. One thing to mention is one skimmer seems to sit about a half inch to inch lower than the other.
My main issue is that scum on the surface of the water seems to swirl on the side of the pool that is opposite the skimmers.
Maybe I just need to chalk this up to a bad design...
DerekBooth
87
Mooresville, NC
Sorry if I'm being a pest, but i have tried all suggestions so far, with the exception of buying eyeballs with smaller holes. My skimmers still are not skimming the entire surface of the pool.
Any other ideas? Very frustrating.
