- Jul 19, 2019
- 9
- Plaster
- Hayward Aqua Rite (T-15)
Hi everyone,
First time poster, long time lurker.
My pool water (and plaster) is about 9 years old. Current chemistry (per TF-100) is:
FC: 1.5
CC: 0.5
pH: 8.0
TA: 50
CH: 1175
CYA: 10
Temp: 75°F
CSI: 0.66
I have a long list of problems:
- Fair amount of scaling on the tiles and rock waterfall.
- The SWG cell scales up/needs acid cleaning every two weeks, but has been bypassed for the last several months.
- The plaster is sandpapery.
- I constantly have to add liquid acid to bring the pH down.
- Algae spots, mostly dark green, with buildup in the plumbing and inside/outside of the automatic cleaner hose. Surprisingly, the water is clear.
My city water has a CH of 200 and TA of 120.
I have a water softener that can be used to partially or fully fill the pool with.
Weather next week is sunny, 70's and 80's.
I'm planning a full reset starting tomorrow, as follows:
1. Have the tiles and waterfall rocks blasted clean.
2. Drain the pool and have it acid washed.
3. Clean the pool filter.
4. Fill water (using meter to figure out the pool capacity).
5. Use powdered CYA, liquid chlorine, and acid to bring the new water chemistry to the correct levels.
6. Add salt and allow it to dissolve.
7. Install a new SWG cell.
8. Install a new automatic pool cleaner.
My questions are:
1. Does this plan sound reasonable? Did I miss anything?
2. What mix of City/Softened water should I fill the pool with?
3. Any advice on how to get rid of the algae in the plumbing/any spots that may survive the acid wash?
Thank you in advance for your help.
Basil.
FC: 1.5
CC: 0.5
pH: 8.0
TA: 50
CH: 1175
CYA: 10
Temp: 75°F
CSI: 0.66
My questions are:
Basil.
