- Jun 2, 2019
- 340
- Plaster
- CircuPool Edge-25
Our tile has been rapidly falling off, and the coping stones have seen better days as well. We had a contractor give us an estimate to repair both, as well as redo our outdated mossy-stone waterfall.
Few questions for the group:
I tried to upload images but it says they’re too big for the server. I’ll post this now and try again when I resize them.
- We have Oklahoma flagstone. It’s nice that it is nonslip, but it also sheds grit and flakes pieces of stone off. Is this still the best nonslip option for Texas?
- He quoted us $250/ft to repair the “broken beam” which he says he thinks is the root cause for the tile falling off. Just rough measurement from the exposed areas where tile fell off, that’s at least $2500, if not significantly more. That 10 feet would alone would cover redoing the tile again all the way around. Are there other effects we should be concerned about if we decided not to repair the beam?
- We have always had what looks like calcium or mineral buildup on the tile, above the water line (usually top of the tile). We are now seeing little hard white mounds show up on the plaster. We had not been concerned about resurfacing just yet, but if this is a sign we need to resurface, can it be done after the tile work or does it need to be resurfaced at the same time?
