- May 7, 2013
- 50
- Plaster
- CircuPool Core-55
I had my pool built in 1998, I managed to nurse it through the last 7-8 years using advice here and it's given me a pretty good understand of what I would do differently next time, and so that was our thought process going through bids and listening to some very talented pool and deck people in the DC area.
We're going with a paver deck instead of concrete this time, and instead of traditional plaster, we've chosen WetEdge Signature Matrix.
In speaking with the pool renovation people, I asked them if they balanced the water before they left after the plaster install, and they indicated it was my responsibility. That didn't scare me, I've been maintaining the pool for 20 years, but I realized that I needed better water testing equipment, and a better understanding of the startup water balance procedure with new plaster.
So I picked up a good deal on ebay for a ColorQ Pro 7 kit, I purchased the mobile Pool Calculator (which I think is affiliated with you guys), and I purchased the "Pool School - Trouble Free Pool" ebook from Amazon
I understand pool chemistry pretty well, but I'm a little puzzled on how to start from scratch with plain water and new plaster. It appears to me that what I need to do fairly quickly is
1) Add Sequestrant
2) Add calcium to avoid the tap water leaching from the new plaster
3) Balance the pH using a combination of Borax and Muriatic acid.
Unfortunately, I'm not sure of the correct order, and obviously this doesn't address TA or CYA. I did a brief search and I didn't see any posts addressing this specific situation, so I apologize if my search skills aren't up to snuff.
The fill date is probably at about 4-5 weeks away based on the schedule, and it will be filled from a water truck from county water (since I have a well). But I want to be equipped with a plan and have the chemicals on hand to get the chemistry correct right away.
Help would be appreciated.
1) Add Sequestrant
