So we are down to the final negotiations with our most preferred builder. Very similar to a previous quote with the exception that this builder uses Hayward equipment.
Let me know if yall have any input/suggestions.
Thank you!
POOL
POOL SIZE: 15’ X 49’
PERIMETER: 144 LN.FT.
AREA: 773 SQ.FT.
BENCH : 2
STEPS : 2
DEPTH : 3 ½’ – 6 – 3 ½’
TILE : 2” X 2” Frost Proof Decorative Tile. Tile markers on steps and benches.
COPING : 1’ of TRAVERTINE AROUND ENTIRE POOL
PLASTER : PEBBLE TEC/PEBBLE SHEE – TIER # 1
DECK : 1000 SQ.FT. OF TRAVERTINE TILE (CEMENT BASE), VERSAILLE PATTERN, WITH ALL DRAINAGE
STRUCTURE INFORMATION
LIFETIME GUNITE SHELL WARRANTY THAT IS TRANSFERABLE TO FUTURE OWNER.
STEEL REINFORCEMENT: 12”x18” Bond Beam – 4 Bars #4 (1/2”) continuous. Walls and Floor - #3(3/8”) 8” on center.
GUNITE : Walls and Floor minimum 9” thick. Gunite Bond Beam 12” x 18”
PLUMBING : 40 LN.FT. Heavy wall Schedule 40 PVC pipe size 2” for all out lines and 1 ½” in return lines. Gas Line connection if required.
SKIMMERS: 2
RETURNS: 10
MAIN DRAINS: 2
POOL EQUIPMENT
FILTER: 525SF CARTRIDGE
CHLORINATOR : YES – INLINE
OZONATOR : ULTRAPURE
PUMP : ECOSTAR-VARIABLE
POOL LIGHT : 2 COLORLOGIC (LED)
CLEANER : POOL VAC ULTRA
SPA
SIZE :TRIANGLE SPA 12’ X 8 ½’ – RAISED 18” – 13 FT. LONG SPILLWAY – ALL EXTERIOR COVERED WITH FLAGSTONE LEDGESTONE.
SPA PLUMBING
JETS : 8 (4 ARE ROTATING)
MAIN DRAINS : 2
RETURNS : 8
SPA EQUIPMENT
HEATER : 400,000 BTU’S
BLOWER : 2 HP
SPA LIGHT : 1 COLORLOGIC
CONTROL SYSTEM : PROLOGIC PS-8 + AQUACONNECT REMOTE POOL MANAGEMENT SYSTEM + AQUAPOD REMOTE CONTROL
TANNING SHELF : 12’ X 8’ INCLUDES 1 LED BUBBLER + 3 BUBBLERS ON BENCHES
RAISED WALLS : 24 FT. LONG 18” RAISED + 27 FT. LONG 12” RAISED. FRONT COVERED WITH LEDGESTONE. INCLUDES 4 – 48” SHEER DESCENTS + 1 HP TRISTAR PUMP.
Price does include the following :
Homeowner Association , City and any other required permits.
Demo : Remove and haul away 512 sq.ft. of existing concrete patio, fire pit, planters and pergola
Sewer and Water stubout for future kitchen/bathroom
Removal and Re-installation of Fence for construction access.
Replace any damaged grass. Repair & Cap any damaged sprinklers
Test Kit, Brush, Net, Telescopic Pole, Hose & Vacuum Head
Final Clean up.Start Up.
Thank you!
POOL
AREA: 773 SQ.FT.
BENCH : 2
STEPS : 2
SKIMMERS: 2
RETURNS: 10
MAIN DRAINS: 2
POOL EQUIPMENT
SPA
SPA PLUMBING
MAIN DRAINS : 2
RETURNS : 8
SPA EQUIPMENT
BLOWER : 2 HP
