I have a rectangular in-ground pool, 12'x24' that goes from about 4' deep to about 5'5" deep. Online calculators put it at about 10,000 gallons. The pool is screened in and doesn't get dirty at all. I have no trees that lose leaves or put out pollen or anything.
Currently there is a Century HSQ165 pump installed, it says it's 1.65 horsepower. It runs fine, but I would like to get a variable speed pump to save some $$ on electricity. Pool season is all year round here and I think I could run the pump on low speeds most of the time just to pass water through my solar panels and SWCG. I would bump the speed up for an hour or two a day to run the suction cleaner.
I have a 100 sqft cartridge filter, a Jandy CS100 that I just installed. I have three lines coming into the pump, a 2" line for the main drain which I keep closed, 1.5" for the skimmer, and 1.5" for the suction side cleaner. Going back into the pool is a single 1.5" pvc line going into the ground, I don't know what it looks like after that, but there are three return jets in the pool. No spa or anything special. I will probably be adding a heat pump at the end of the year as well.
That being said, it seems like a 1hp pump would probably be sufficient. I just don't want to make a purchase I will regret and see poor performance from my suction cleaner! Would it be a better investment in my situation to go variable speed, or two-speed?
Also, I prefer to do my own work, is Pentair or Hayward better when it comes to warranties and not using a pool company for installations?
