I maintain my own chemicals and have for many years. I've never had an issue. I use a pool company for opening and closing and normally ask them not to put any chemicals in. Today they arrived to close the pool and misunderstood my request for no additional chemicals. Something they did caused my PH to go from 7.4 to 9 or even 10 (maybe).
Numbers as the pool company pulled up:
FC - 11
TC - 11
CYA - 60
PH - 7.4
TA - 90
Salt - 3600
Calcium - about 600 (very high calcium well water from auto fill)
Pool is 26,000 gallons
My plan was to slam the pool after they drained out some water and before they put the cover on. I was talking to one of the guys who was working on the pool heater and when I turned around, another guy dumped in 2 bottles of GLB algimycin 600 (algicide). GLB Sequa-sol (Sequestering agent?), and pool magic (no idea what this is). I never use anything other than stabilizer in the spring, muriatic acid to bring the PH down, and liquid chlorine when I need to supplement the salt cell. I add salt in the spring too. I've never needed any of these others items they dumped in.
After they dumped these items into my pool, the PH test now turns a very dark purple as if the PH is 9 or 10 (off the chart). I am 100000% sure the PH was 7.4 when they arrived. I use a Taylor K-2006 test kit with refills from TFTestkits. Could one of the items they dumped in cause the PH to spike or the test to give a false reading? I double checked the chlorine and they did not add any more chlorine so it is not a case of very high chlorine washing out the PH test. Could the PH suddenly be 10 from something they did? I don't want to dump in acid if it is not needed and cause the pool to be too acidic. I have not added more chlorine because I know it will simply destroy the algicide and in turn cause combined chlorine. Any advice for this mess would be helpful. Should I add acid? When should I slam since they added all this stuff which the chlorine will just break down if I slam and it will defeat the purpose of the slam. Thank you!
FC - 11
TC - 11
CYA - 60
PH - 7.4
TA - 90
Salt - 3600
