Hello, I a m planning on opening my pool later this week and already know the water is a dark green with algae after taking a peek under my mesh cover. I will be performing a SLAM but wanted to ask about steps prior to that. With the water level high should I backwash to drain some of the water and clean the filter out or just drain through the waste line? I never had to backwash last year as my pressure never went beyond 8-10 of my normal starting pressure. I also did a deep cleaning of the sand filter a week ago but I feel like it could be cleaned more. After draining the water I should let the water circulate for 1/2 hour and then test the water. Add what I need, retest the water then start SLAMMING when CYA and PH are good?
