I have an oddball shaped salt-water pool (see attachment) that was finished in Sept 2020 (so I really haven't had a real chance to swim in it) and am currently experiencing a pretty significant dirt and algae issue. I thought the dirt and algae was sand, but the guy who installed my pool says its algae (sinking algae). Plus, the color of my pool just isn't nearly as clear as I think it should be - especially when I compare it to pictures of TFP members' pools.
This is my first pool and I don't know a thing about pool maintenance or chemistry. I anticipate this website will be a godsend to me and I will undoubtedly become a Supporter. I've read a number of posts and articles from the site, but anticipate the best help is just to ask for it.
First, a few things:
1) I need to buy a pool kit still. And will do so. It appears the TF Test Kits are popular with a lot of veterans on the sit so I had planned on going with one from there. I have a salt water pool. Will the TF-100 kit be sufficient? I saw another test kit on the site (TF-Pro) and it says that it's "..with SWG." Do I need something with "SWG" instead?
2) Until I purchase a new test kit, I have one my pool installer left with me. It "measures" pH, chlorine, & bromine. According to this kit (see the other attachment), my readings are:
a) pH: 8.2+
b) chlorine: 0.2 or lower
c) bromine: 0.4 or lower
d) salt level: 2400-2600ppm (my Hayward app reads it as 2600ppm. A salt water meter I purchased had it reading at 2380ppm).
i) Based on that info, I also know I desperately need to add salt. My pool installer though is kindly coming by the house tomorrow/Monday to try to vacuum the algae out. So I was going to wait to add salt until he does that because I think he's going to "waste" a lot of the water as he's vacuuming.
3) My city water is EXTREMELY hard. We have a water softener for the house, but the water that usually goes in the pool isn't softened (it's just from an exterior tap). Prior to putting the softener in, my water tested at 30 gpg----no, that's not a misprint. It's in fact 30 gpg.
I understand that you might not be able to offer any help until I invest in a better test kit. So maybe we should start there?
Which specific TF kit should I buy and what Optional Items, if any, should I add on? I also don't mind spending the money on the Pro package if that's what I need.
a) pH: 8.2+
