Pool math question
val8375
Active member
May 18, 2022
40
Hays ks
Hayward Aqua Rite (T-9)
I have a swg and my cya is at 60. Pool math says target fc is 7 which is what I keep it at but I get so itchy in the pool. I have been reading that fc only has to be at 7.5% of cya so wouldn't target be 4.5? I really want to keep fc lower to see if itchiness goes away.
Thanks for the imput!
You can run a lower FC if you wish. The potential for algae is much higher. Your choice.
Keeping pH in the 7's is more likely to solve your issue.
Reactions: val8375
Ok thanks but Am I running fc too high at 7? Do you think according to the 7.5% of the CYA It should be like around 5?
Running the FC in the target range, or above, is fine. Less likely to have issues if you have a day of high organic loading or a SWCG issue.
No that's flirting with minimum which ironically may cause swimmers itch if bacteria flourish.
I run mine 'hot' at 10 to 14 and nobody knows.
Reactions: SoDel
