I replaced my SWG cell and refilled my pool a few weeks ago and have been trying to get the chemicals balanced since then. Here are my numbers today as tested in the local pool store:
FAC: 5
TAC: 5
Salt: 4000
CH: 180
CYA: 70
TA: 100
pH: 8
Temp:62 degrees F
Pool Math calculates my CSI to be -0.16 with a suggested goal of -1, but the comments in the field to the right say anything less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools. Why would it suggest a goal lower than a safe level, and how are the goals set in Pool Math? In the Suggested Goal Levels field I selected TroubleFreePool.com but in the pool surface drop down there is no option for pebble sheen, so pH, TA, CH, and CYA all show Goal: Not Setup. Is one of the options in the drop down have the same target values as pebble sheen? According to the pool store and from what I've read here on TFP, the CH is low but I'm leery of raising it since my water is very hard and in the past regularly had calcium buildup in the cell. Any suggestions on how to set the goals in Pool Math and save them is appreciated!
FAC: 5
TAC: 5
Salt: 4000
CH: 180
CYA: 70
TA: 100
pH: 8
Temp:62 degrees F
